Online: clackavosticus
Grips
  • 883n Harley Convert
    883n Harley Convert
    Definitey fit!!
  • terroristone
    terroristone
    Dual cable is what you need.
  • Will67
    Will67
     id be a bit dubious about them mate, see the left side grip i think it should have a peice that locks into the switch housing so they dont slip off. your choice brother,you get what you pay for.
