Brake lines
  • IronKnapp
    IronKnapp
     G'day Guys
    I have a small drama, just fitted some drag bars to the iron and due to the change in height etc the right side brake line does not fit as nice.
    I have seen a post on here with someone stating a fix for this, had a part number and all. Of course I can't find it, any help is appreciated.
    Regards
  • slapster
    slapster
    That could have been me. You talkin about the tight kink in the brake line? Part number for HD Diamond Black braided line is 41800178 about $108. Perfect fit.
    Slap.
  • IronKnapp
    IronKnapp
    Cheers Slap
    That is the one I had seen, appreciate it. Will put my order in tomorrow.
    Regards
  • GT 1200
    GT 1200
    Hey guys, is that brakeline one piece? I have the same problem with my custom which has top and bottom hoses with a section of tube in the middle. I want to change them to braided. Cheers
  • darkdesign
    darkdesign
    for $80 you can get a whole custom braided line from Hydraulink or others, made to your spec, in what ever colour u want.
  • GT 1200
    GT 1200
    Thanks Slap, couldn't see it there but think I will use the "how long is a piece of string?" method.
