Online: clackavosticus
stg4 103" - which exhaust?
  • stumbly1
    stumbly1
    G'day all,
    Been reading up a bit trying to get an idea of what way to go exhaust wise.
    stage 4 103" with (I think ) the SE259e cams.
    The US forum has a few threads saying that a 2 into 1 is better for torque in the lower end / midrange using those heads & cams, 2 into 2 for the top end.
    Not being technically minded with cams & heads & shit was hoping some of you might have already gone down this road?
    Chasing useable midrange, not really looking to ring its neck all the time, so whaddya reckon?
    cheers, stumbly
  • Ando
    Ando
    I am a 2:1 man
    brands that are good are
    Freedom exhaust
    D&D
    Rinehart
    Bassini
    V&H pro pipe
    Supertrapp
    I would also look at other brands of kits
    S&S
    Tman
    fuel Moto
    R&R Cycles
    just a couple
  • chriso
    chriso
    I put a stage 4 in mine and did alot of research. it was Ando who pointed me in the direction of a few of the above brands, i went with the D&D fatcat and cant be happier.
    Lots of diff opinions but i think it is of major importance to complement a proformance engine with a good set of 2 into 1s. Ive had builds before and always run 2 into 2s
    and my mechnic has said for years put 2 into fucking 1s on. well i have this time and i have great mid range which is where i want my power. I would never go back.
  • stumbly1
    stumbly1
    cheers fellas, looks like thats the way i'll go then.
    Hey Chriso, any advice on a good deal for those fatcats?
  • stumbly1
    stumbly1
    Yeah I've bought a bit of stuff from M&M's so I'll go with them, just thought you might have got a reasonable deal somewhere in oz.
    Ando, going on a brand spankin '13 fatbob.
    Getting all the work done before pick up mid oct.
    yeah, I know, fkn expensive way of doing things but being 2 n 1 fifo I always run out of time. Another bloody overpaid cashed up bogan apparently.
    Besides, ya uncle porky just got a brand newie so gotta keep up with the jones's eh?
  • chriso
    chriso
    The reason i asked what they are going on is because D & D have not make up the righrt bracket for them to fit on the models with ABS yet and are still sending the old ones out.
    It is an easy fix though to modify the bracket but just giving you the heads up.
    Check this out
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=4&tpage=16&view=Topic&postid=447425
    Maybe they will have new bracket sorted by the time ya get yours
    PM sent
  • stumbly1
    stumbly1
    cheers chriso, I've been having a bit of sticky beak at your last couple of threads - all good solid info from yourself and the blokes commenting. thanks for the heads up.
