FXR battery seat question
  • Dutch
    Dutch
    Hi guys,
    time's up & I need a new battery. Noticed some time ago that the original harley seat has a 'bump' on the bottom so it wouldn't fit with the dodgy aftermarket battery that was fitted; the fitted Le Pera is flat so it wasn't a problem.
    As I want to be able to fit both seats, do FXRs require a particular battery to accommodate for the hump in the seat or will normal batteries do that anyway? Or do I need that flash 'Original HD' battery?
    cheers...
     original harley batterys are the best bet & last longer , or buy a deca brand  sealed type   keep away from the old wet one's
  • Dutch
    Dutch
    thanks DR, question though was rather what battery fits underneath the unusual seat instead of which is a good quality battery... anyone?
     YB16B
  • Dutch
    Dutch
    I'll check it out; thanks mate
