2010+ wide glide rear lights?
  • robots
    robots
     Hi,
    Wanting to improve the rear light set up on my 2010 wide glide.
    Any ideas, good results, products you may of used. So far am looking at the Biketronics Tailstopper, Biketronics Tailbones, The Illuminator or i believe theres a Harley turn signal module?
    Even looking at a couple of push bike lights to attach to the signal sticks.
    Thanks
    robots
  • ==ShaDoW==
    ==ShaDoW==
    made my own,
  • robots
    robots
     hi,
    nice bike shadow, beautiful
    thanks
    robots
  • robots
    robots
     hi,
    well i happened to come across a module to make the turn signals come on when braking, just take seat off and plug it in,
    I made a video but dont know how to post it (its an avi file), if anyone can tell me how would be great
    not sure whether to change lenses to red or not, will wait and see
    thanks
    robots
  • Sparra
    Sparra
    Thats how they are in the States...Pretty sure it's illegal over here,that's why they have a tailight on them...
  • FatRob
    FatRob
    The Irons and some other sportsters have the 'no rear light' set up over here.  The indicators are multi light units and hold the rear, brake, and indocator lights in the one (two) units.
    Personally I like the brake light in the conventional place as that is where idiot car drivers expect it to be.  Put it somewhere else and they are even more likely not to see it.
    FatRob.
  • robots
    robots
     hi,
    i still have the normal led tail light on fender, its just so small
    now the indicators light up as well when brake is on
    thanks
    robots
  • robots
    robots
     hi,
    well cant get the video on youtube, so took a few photo's
    this is about 5.30pm, so the indicators light up when you apply the brake,
    thanks
    robots
  • Sparra
    Sparra
    Thanks mate,will do...Hey Robots do your blinkers still flash when you have your brakes on???
  • robots
    robots
     Hi,
    Yes the right will flash and the others will stay on,  vice versa when left flashing
    Its called biketronics tail stopper, about $100, I will keep you posted
    Thanks
    Robots
