Online: speedzter
Pipes on a 2010 Wide Glide
  • Sparra
    Sparra
    Just wondering if you changed to pipes on a stock 2010 Widey do the 02 sensors pick up the change and nothing else needs to be changed or tuned???
    Cheers...Sparra
  • Ando
    Ando
    yes you will be fine
    but a tune regardless is a good idea, the dam things run lean as is
  • rider
    rider
    Ando's right, and you'll find that without a tune she'll run too lean and the decel pop/bang will drive you nuts.
  • paulsails01
    paulsails01
    Nothing wrong with your take Hilly, we have all gone the re-tune road as we know that the OEM tune is purely for the EPA compliance, it has nothing to do with a more efficient cooler running engine and heaven for bid if you unleash a few extra ponies whilst improving tune.
    By the way is there a "prefered or known distance" that the O2 sensors should be positioned down the header pipes? I dont believe I have seen anything on this yet.
    Paul
  • Sparra
    Sparra
    Thanks for the reply's...The reason for the question is that I am looking at a couple of bikes,one new with pipes,air and tuner...one almost new that is stock...I can save about 7g's with the stock bike and add the extra's as I can afford them...i already have some pipes with 02 plugs in them on my evo that I thought I could put on the stock bike and save a few $$..I could probably buy pipes,tuner,air and get it tuned and dyno'ed and still be cheaper than the new bike...Oh..the new bike is a Switchback and the other is a Wide Glide...
    Cheers...Sparra
  • Sparra
    Sparra
    OK...The new pipes are on(Bassani Road Rage)...I haven't ridden the bike yet but when I do if it doesn't pop and carry on can I assume it won't be too lean...The nearest dealer to get a tune is a 2hr ride and i don't want to do any damage on the way over...TTS is on the way when the new model is in at M & M...
    Cheers...Sparra
  • Iolis
    Iolis
    I changed my stock mufflers to V&H 3" slip on's fuck she has heaps of decel pop and backfire etc. I didn't think a muffler would change that much?
  • Sparra
    Sparra
    Yeah mate,Mark sent me an email yesterday...I put the new pipes on and went for a squirt and it is running great..No popping on decel so I should be right until it turns up...
    Cheers...Sparra
  • bradtheman
    bradtheman
    If you are just modifying the pipes, from stock, then no worries. As soon as you mod the air filter, You ABSOLUTELY MUST get a tune. No ifs ands or buts.
    NOTE: If you don't change the air filter at the same time, You are all but guaranteed to lose power.
  • the_mongrel
    the_mongrel
    Bikes need a tune out of the showroom I reckon!! :)
