Online: baldy1450
Abnormal tyre wear
  • MUZZ101
    MUZZ101
    I have just had to replace my rear tyre due to the edges being scalloped/ feathered.
    The tyre was an avon venom on the back of my 2006 Softail deluxe and only had about 2000kms on it.
    It still had a heap of tread on it and had been a great tyre until now. Plenty of grip.
    What could cause this. Anyone have an idea?
  • Will67
    Will67
     Under-inflated maybe!
  • ozymax
    ozymax
    yep that would be my guess
  • TheBigT
    TheBigT
    Do you have a pic of it? Was it the leading edge of the tread pattern or the trailling edge (if you can remember)? It may be a pressure issue or could be dampening issue with ya shocks?
    Also good to know if you were carrying any extra weight.
    Did it start scalloping from new or only the last legs of its life?
    Just keep an eye on the new tyre before it destroys itself cos you could have a stuffed shock.
  • MUZZ101
    MUZZ101
    I dont have a pic of it. It wasn't under inflation as I keep a good eye on my tyre pressure.
    I'll have a look at what edge it was. No extra weight except for the fat bloke riding it.
    Nothing has changed with my riding but a mate has the same tyre and it is worse than mine.
    I'll check the shocks and keep an eye on the new tyre. Its a bridgestone this time.
    I never had a problem when i was running the dunlops only the avon.
    Cheers for the replies
  • TheBigT
    TheBigT
    Such a pity the shocks aren't adjustable for the different grades of tyre, and the problem is as the shocks start to wear the damping gets quite a bit softer, less rebound, less compression, the tyre sees the effect. You can adjust pressure to compensate a tiny bit but just keep an eye on the new tyre. Poor rebound, especially on the front, is evident by the leading edge of the tread pattern being raised. Incorrect tyre pressure has differrent characteristics on different parts of the tyre so if at all possible post a pic or a diagram of tne tyre.
    Lots of factors to consider tho, air temp, tyre temp, weight, and where/how you ride.
  • oneball
    oneball
    Hi all...That is normal wear for tyres being ridden hard,Softer tyres more exagerated.
  • Normthe1
    Normthe1
    I run the Avons and have 3000 km on them so far and they still look like new. I do go easy on them though...
    Norm
  • MJ
    MJ
    bob never had issue with metzlers ....... and dunlops are shocking in the wet ....
    have to agree with tony pressure or shock ......
  • chriso
    chriso
    Yeah i could tell some storys too but yeah its the age old debate hey? diff people diff experiences whatever works for one may not for the other.
  • MJ
    MJ
    well i do ride in all weather and prefer the bike under me instead of sliding down the rd away from me
    and never had a issue with the metzy's
