Change my brake line?
  • ConR
    ConR
     I'm useless with rulers, and most tools in general for that matter.  I fail at assembling IKEA furniture.
    I have a 2012 883 Iron.  I'm running Friscos right now.  7" rise.  I'm OK with the stock brake line, but I have bent it a bit to make it reach.  I'm adding a 2" riser to the bars.  I'm hesitant in thinking the stock line will still fit.  So, anyone point me to what length cable I should be looking at going with?  I think the throttle/clutch cables should reach.
    Appreciate any info!
  • Ross
    Ross
    have a look at the thread in General Discussions. It gives you what was stock and a rough formula for calculating the new length depending on the changes you make.
    http://hdforums.com.au/Default.aspx?tabid=71&forumid=15&postid=453752&view=topic
    Its only rough, but will give you a bit of an idea.
  • ConR
    ConR
    Thanks mate. Will have a look at that!
  • ConR
    ConR
    Any idea if a silicone based brake fluid would work in a Harley?
  • terroristone
    terroristone
    Use the hd one for 8" bars, diamond black braided. Dot 4 brake fluid is fine.
    T1
  • ConR
    ConR
    Sweet. Thanks dude!
