Online: Stuart
Repco Bike Jack
  • chopa
    chopa
    Just Letting You  know Repco has bike lifts on sale for $149 Again
  • Bakes68
    Bakes68
    Thanks for the post, I've been waiting and would have missed it again
  • 45WL
    45WL
    Just check their website $139 until 2 Sept
  • Bakes68
    Bakes68
    Got one today $139, works great thanks again chopa
  • Roosta
    Roosta
    Cheers Chopa..
  • tallmac1959
    tallmac1959
    YEP! Had mine for a while now. Lifts and hangs on to the Heritage quite well.
  • chopa
    chopa
    I bloody work ar Repco you'd think I'd get the price right
  • Superglide2012
    Superglide2012
    This might sound stupid (im good at those questions) but what is the right way to lift a bike with these jacks?
    Do you approach from the stand side or the high side?
    Do you hold the bike?
    Etc.
    I could see the bike tipping if approached from the high side without some assistance.
    Am I over thinking this?
     Hi SG2012. check ya pms.
    Approach from rhs and slide lifter under, and just poke it out about an inch past the lower cradle on the stand side. then keep stand down just in case and hold right grip while pumping up lifter.
    Bike will start to stand upright and just keep lifting untill you are happy with the height. Tigger handles it no probs as did my last 3 harleys.
    To let it down just do it in reverse but let it down gently. Don't just stamp on the lowering pedal or you will shit yourself.
    PS i don't use tie downs either. My bad!
  • terroristone
    terroristone
    Another tip is when the wheels are just off the ground and you are still holding the rhs grip rock the bike a little to check that you have it in the right balance point before you get too high.... i only use tie downs when doing major work or when the bike will be "rock" buy undoing tight bolts etc.
    When lowering as said press the leaver lightly otherwise you may find your bike on its side..... before lowering all the way make sure stand is down and keep a hold onto the rhs grip....
    And of course use some common sense.
    T1
  • terroristone
    terroristone
    i remember reading a while back that somebody lowered their bike, while wearing thongs and stand up and bike hit the floor....they didnt even check the stand...... triple check things guys, buying tools dosnt have to make you one!!!! Work safe and take NO chances.
    T1
  • Colstah
    Colstah
     I just got one too, thanks for the heads-up Chopa.
    I was a little disappointed with the quality, it is a bit rough. Having said that though, I've had my softail up on it and it was steady with no apparent problems at all! At $139.00 I shouldn't grumble, been wanting one for a long time, just couldn't part with the cash. I'd get it again and don't regret buying it.
    How important is it to get the bike balanced relative to fore and aft, and where is the balance point?
  • Crazy Erny
    Crazy Erny
    Thanks Chopa. just got back from Repco Loganholm where I paid only $139.00 for mine! Works a treat, looking forward to cleaning the bike mow as it's at eye level.
  • Iolis
    Iolis
    so do you need lift blocks to use these jacks or will they lift a Dyna as is???
  • terroristone
    terroristone
    You will need lift blocks for dynas.
  • ozymax
    ozymax
    why?
    I dont have a repco lift but mine looks no different really and no lift blocks needed
  • ozymax
    ozymax
    no mate goes across behind the sump.
    maybe thats the difference. mine has the rails spaced further apart perhaps
  • Superglide2012
    Superglide2012
    I'm writing this in my book! I asked a question that wasn't stupid.
    The replies were very informative and I thank you all for the great replies.
    Onya gentlemen.
  • ozymax
    ozymax
    they only stupid question is the one not asked
     Unless you ask the missus if her ass is gettin bigger!  ouch!
