Remove cats from my '10 Night Rod
  • ralphski
    ralphski
    Any info/drawings etc on where to cut the pipes to remove the cats from a 2010 DX. Then i'll get the pipes re tigged back up. Thanks guys
     i have a dog that will get rid of them cats for you , he's a stumpytailed  red hall's  heeler,  no worries
  • ralphski
    ralphski
    Can u drop him off? thanks
    there's always one...
    the BITCH red stumpy has just had 6 puppies  only 1 week old ,  all halls hellers so we have  9 stumpies here ,do you want too buy 1 ,
    i have done this mod to the exh  before a few times ,   you straight cut across the guts very neat  it's a bit hard too clean out  because there  glued in  but you can do it no prob's just clean all the old glue out proper  , the cat  metal is worth scrap $ like 50-80 bucks  , do not breath the dust wear a mask , then tig weld neat  & narrow i just paint a thin strip of silver paint  down the weld  & screw the chrome cover  back on,    you would never know . or you can buy a yankie model header pipe they do not have the pussy cat in there header buy they could be 500-700 buckaroonies,
  • ralphski
    ralphski
    Kids have been whinging about a dog of late....
    Have got the info i wanted.
    I'll pull the pipes and cut off the rear end and smash the honeycombe cats out etc then re tig. Hopefully be running abit cooler etc.
    thanks, 56
     don't forget too wear a mask, & clean out the glue stuck to the inner walls  wire brush on a drill etc i polish in there  smooth with sandpaper scrolls & finnish off with very fine with some kero, you might have to re-tune the bike it might come out a bit lean mixture that will make her run hot ,            our puppies will be on the trading post  & the land newspaper.com next week we start to add  them @ 2 weeks old  & take dep 1st so by the time 8 wks are here we make sure the people still want them or i give the dep back too make sure they go to good homes etc ,     just like you would not sell your bike to someone who could not look after it ,
    these dogs are the true stumpytailed halls heelers as they have some dingo in the breed, my males grandpappy was a 100% dingo  both dogs are from working farms , very keen & loyal the last lot 5 out of 7 went to farms as pets  & watch dogs we have had reds since 1983 we spoil them as the puppies a born in the lounge room in the basket & the mum is hand feed  the puppies are very fat & strong
