Online: Retroman
Changing one tire only?
  • ConR
    ConR
     Apologies all. I'm a noob when it comes to bikes and have been asking lots of questions.
    My bike is pretty new. Just got it two weeks ago. I'm wanting to throw a whitewall on the rear and keep the front as it is. Can I do that or should I change both up?  I've done 500 kms on it so far.
    Appreciate any info!
  • ConR
    ConR
    Apologies for the Canadian spelling of tyre :)
  • russ4570
    russ4570
    i'd replace one.
    Normally do anyway as the rears wear out at two to one front.
  • ConR
    ConR
    Does Michelin make a whitewall that would match the tread on the Scorcher?  Or is it ok to run different brands being so new?
  • russ4570
    russ4570
    Not sure about the pattern, but as long as the tyre meets the manufactures minimum specs (see your manwell) then all is good. Matching brands is not a necessity.
  • FLSTC
    FLSTC
    why the hell not .. keep the old tyre for when you get sick of the mismatched look
     i'am not as young as i use to be  so i only do 1 @ a time,   or i get 2 tyred
  • the_mongrel
    the_mongrel
     OH.... That's just a shocker!!!
    thats exactly what  my women said when she 1st seen it,  but she is just use to me now
