Online: Merv
Tour Pak spoiler/LED brake and tail light, denim black covers and edge cut gear.
     G'day forumites, I spent a few hours adding some new essentials to Tigger today.
    First up was a new derby and timer cover.
    Then I put on a new denim black horn cover and bracket.
    A new brake pedal and 2 shifter pegs from the edge cut collection to match the shifter linkage.
    And finally I installed the new Tour Pak spoiler with LED brake and tail lights. The colour is a perfect match too. Goes well with the top box. Added safety with the high mount brake light to.
    Tigger has never been so happy.......Still got more to go...slowly slowly..............
  • Burnzi
    Burnzi
    Very nice, I have seen the spoilers on an ebay site (aftermarket) they look great.
    Tigger's lookin very smart!!
  • mickle
    mickle
    Looking good.
  • Superglide2012
    Superglide2012
    Sweet
  • Fe883
    Fe883
    Neat looking bike.
    Can i ask what the color is please.
  • rider
    rider
    Lookin Good.
    And a new Billet brake lever arrived!
    Here is the whole package.
  • rider
    rider
    I can feel a set of bilet top box hinges coming on.
    (if ya haven't already checked em, while ya got the tools out, run a socket over the exhaust manifold nuts and re-tension em, ya might get half a turn out of em!.)
    Billet shifter levers to match the rest.
  • rider
    rider
    With the hinges, I did read the destructions but did a coupla things different.
    I fitted them one at a time so as not to have to take the lid right off, I've got a lot of wiring and stuff that made it easier to leave the lid on.
    Only other thing I found out was that the holes in the lid where the locating dowels on the top part of the hinge go, were a little tight, so I reamed them out a micky whisker with a 4 mm drill,,, that allowed them to be started a lot easier and pulled up just nice with the two screws and clamp.
    You'll see what I mean when you go to fit em.
    Apart from that, no probs, 20 to 30 minutes shoud see ya done takin it easy. Then polish, sit back and admire,,, they make a huge difference to the appearance.
    Oh ! nearly forgot,,,,,, the black leather bags that fit the rear crash bars a pretty snazzy as well,,,,,,,,,,,,,
    k. TourIng SaddLebag guard bagS
    Synthetic leather bag features an embossed Bar & Shield
    Logo.
    90955-97 Left Side.
    Fits ’80-later Touring models equipped with saddlebag guard
    rails. Does not fit Comfort Profile Guard Rails.
    90939-97 Right Side.
    Fits ’93-later Touring models equipped with saddlebag guard
