Solo reg versus what? Dual?
  • Colstah
    Colstah
     I just read Mick44's post about his experiences getting info pre-reg, and particularly the solo thing.
    Thing is, I've always wondered why my Softail Springer is registered as a solo body type. As far as I know (and it may be a detail I've missed) it's always been registered as a solo (I bought it new in '94). It came off the showroom floor with back pegs and a two up seat and stock standard everything. I just figured that was the way bikes were registered....
    Now this didn't really concern me 'cept when I read the comment about it affecting CTP!
    Any opinions on what my next course of action should be? Am I running a risk of liability if the missus comes on the back?
    I was thinking of taking the missus out on the new bike when it arrives and that post caught my attention too - mainly because I've never thought about it before. I read somewhere that in Vic it doesn't matter, but I remember the lady at the RTA asking me 5 or so years back when she looked over a bike I bought so I have NFI,
    I had a read on the Vicroads sites and couldn't find squat so maybe I'm looking for the wrong thing...
  • Colstah
    Colstah
    Oh yeah, harley, you may be onto it.
    I just checked the CTP categories on the gov website here in SA (good idea Bonkerz!), and the only options for motorcycles related to engine capacity, so I'm guessing the solo thing is irrelevant.
    Still, if I tell the missus that she'll have to stay at home 'cos insurance wont cover her......nah, if I got caught out....
  • mick44
    mick44
    Putting this on for info.
    In QLD, you can rego a bike for dual or solo rego, Solo rego is half the cost, The three main rules are,
    1:remove rear foot pegs and weld up threads, wont accept a bolt placed in hole, (allthough i just got away
    with out welding threads up as i argued the threads are used for legal factory accessories.
    2:Seat must be a maximum of 500mm long. Can not have padding on guard behind seat.( seat on my 650
    trailbike is 700mm long and i got away with it because i argued that 200mm of the seat goes up onto
    tank and is designed to protect genitals when thrown forward a bit on the bike and should not be included
    as part of the 500mm length, as you cant sit on that part of seat anyway.
    3:Must get a mod plate, $75, plate is glued on the frame front downtubes, They dont require the frame to be
    drilled and plate riveted, they use a glued on type now.
    4:If you reinstall dual gear and dont re register, and have an accident, the passenger is not covered and youll
    get a please explain, probably a serious please explain.
    Many people have multiple bikes and solo rego is an alternative to being able to afford costs, ect
  • Burnzi
    Burnzi
    Thanks for the info guys it all makes sense now.
    Does anyone actually two -up all the time? So why would the price be almost double if you're only doing it occasionally? One more money making scheme.
  • Colstah
    Colstah
    Rgr, same.
  • dyna gliding
    dyna gliding
    here is the email i sent
    i'm hearing that a motorbike registered as a solo can't have a passenger, if it has a dual seat it has to be registered as a dual is this true if not what is the defination of a solo registered motorbike
    this is the reply i got form the sa.gov.au
    Thank you for your enquiry.
    The motor cycle body types are as follows for registration.
     ·         Solo
    ·         Sidecar
    ·         Tri cycle
    All my bikes have had dual seats and rear footpegs, but they've all been registered as "solo". I was only asked once (as I said above) and she answered for me "of course its solo." - to be honest, at the time, I had NFI what she was asking...seems I still don't :P I guess "solo" must mean "normal bike" - except in QLD...
