Online: Wanderer57
Speedo Adjustment
  • PigironBob
    PigironBob
    Have had my Thundermax in for over a 1,000 kms now and am impressed with it except my speedo is now showing 10 kph slower than the bike is actually going, it was nearly spot on befor the change out.
    Is there any way to change the speedo settings in the Thundermax software?
    Thanks
    Bob
  • slyde1
    slyde1
    I've never had to change it but in the Basic Settings there is a speedo cal window. It looks like yours should be set at 45900 I think. Wonder why it would change. Hope this helps.
    Brian
  • kiteman
    kiteman
    FatBob is shown as 16" front and rear, the other 08 Dynas are all listed at 19' front and 17' rear.
  • widejon
    widejon
    have info from zippers on speedo setttings
    BY PULLEY SIZE
    original speedocal 100000 p/mile
    original pulley 100 teeth
    new pulley 75 teeth
    correct speedocal 75000 p/mile
    BY TYRE DIAM.
    original tyre dia. 25 inches
    new tyre dia. 27 inches
    correct speedcal 92592.59 p/mile
    BY TRUE SPEED VS INDICATED SPEED
    original speedocal 55900 p/mile
    indicated speed 100mi/hr
    pulse rate 5590000
    true speed 107.997 mi/hr
    correct pcount 51760.7 p/mile
    hope this helps thundermax users best of luck
  • PigironBob
    PigironBob
    So how do I apply these formula to the thundermax?
    I am just a simple country lad who finds himself living in the city and rides a Harley.
  • Fantm2
    Fantm2
    You could email Zippers for the correct code to put into your 'Basic settings'.
  • widejon
    widejon
    good question have not had cause to use them yet mayby some of our tech gurus can help or try emailing zippers
  • PigironBob
    PigironBob
    Ok Thanks men.
  • widejon
    widejon
    according to zippers tech line thundermax speedo calibrations are set for american models so if aus versions have different rear pulleys the speedo reading will be out
    by whatever % difference there is in pulley size 06 dynas approximately 3% not alot but worth keeping in mind as your speed increases
  • kiteman
    kiteman
    I have a mental picture of Bob lying under his Fatbob and counting the teeth on that damn pulley!!! :))
  • PigironBob
    PigironBob
    Haven'y had time to look at this yet maybe in the next day or so I will get a chance.  Got to strip the Thundermax out of the caddy to get the communication cable in.
    MAJOR PAIN IN THE ARSE.
  • kiteman
    kiteman
    Is there any way to make some permanent adjustments to the caddy to leave the cable in?
  • PigironBob
    PigironBob
    Ok. So I read the manual last night.  This morning I loaded in the origunal base map I had used (304) and adjusted the Speedo Cal down to 42000 and went for a ride with the GPS, was 100 = GPS and 95 on the speedo, adjusted speedo Cal to 93000 and results where 100 = GPS and 99 = speedo so left it at that. Don't think 1 kph is going to make much diff.  I did check it doing 50, 60, 70, 80, 90, 100, 110 and 120 kph and all the way through the speedo was 1 kph slower than the GPS..
    The original problem was doing 100kph on speedo but was actually doing 110kph, glad I got that sorted before I got any tickets.
