Online: John.R, Hilly
Flat battery
  • Normthe1
    Normthe1
     I fucking left the key on the first click for a week, I was going back out and then it started raining and I forgot about it.  I am a dickhead...
    Anyway, I have had the battery on the fitted trickle charger for 12 hours now and I still got nothing.  Will it need the entire weekend on that trickle charger or is it rooted?  Might it take a jump?  Can you jump Harleys?
    Can anyone help a dickhead out???
    Norm
  • oneball
    oneball
    Hi all...Normthe1,Im sure a trickle charger wont charge your battery,You need a proper battery charger to charge it.If the battery is fucked,nothing will fix it.
  • Normthe1
    Normthe1
    OK guys thanks for that. I will run it down to Battery World this morning and get them to give it a tizzing...
    Norm
  • Normthe1
    Normthe1
    Norm
  • Normthe1
    Normthe1
    1.75 volts.
    Ended up buying a new Deka, have to wait until Monday to find out if it will come good and wanted to ride today.
    $170 lesson fuckit...
  • Normthe1
    Normthe1
    No, Dave, I only left it on the 'first' click, not full ignition.
    I got the new battery installed and she fired right up...
    Cheers anyway,
    Norm
