Online: brucefxdl, Merv
blinkers now not flashing - NOT LED
  • wilso
    wilso
    upgraded front indicators to kuryakyn small halogen silver bullets and just slimline rears that attach to the rear fender struts.
    now they wont flash , checked all bulbs , all light up just wont flash , they do auto cancel when bikes moving.
    the fronts are halogen globes and rears just normal incandescent bulbs.
    the install guide for kuryakyn's say not to run a load equalizer used as turn signals , if wont flash change to 20 watt globes , but they already are 20 watt ??????
    reckon its the turn signal module ?  FXDWG dont run a relay according to parts breakdown circuit.
    anyone similar issues , shed some light ?????
     i think you mean downgraded the blinkers ,  if you want that crap to work you will need a load equalizer
  • markfxd
    markfxd
  • wilso
    wilso
    fixed , got a new module , thanks for the value adding advice daddyracer56 ......btw , no equalizer required...........
