Online: John.R
Guageface
    I've never seen this before so it might be helpful to someone here.  Its a jigger that connect your bike to an iphone app:
    Its $265
    Charges device     iPhone & iPod touch     Dude... you won't get too far without charging!
    Diagnostics     Unknown...See below *4*     Beta!!! New in version 2.0... Initial support for AFR, MAP & TPS. Working to expand support for other readings such as Injector Pulse Width (IPW), Block Learn Multiplier (BLM) & Ignition Advance (ADV).
    Customizable Gauges     All supported     New in version 1.6 of the app.
    Speedometer     All supported
    Tachometer     All supported
    Trip Odometer     See below *3*
    Engine Temperature     All supported
    Gear Indicator     See below *1*     If you are also running ThunderMax, make sure to use their latest firmware.
    Turn Signals     All supported
    Orientation Auto-Lock     All supported     Orientation is locked to match the active GaugeFace (skin) preference when connected to a running bike.
    Orientation Auto-Lock     All supported     Ability to select and lock orientation based on user preference.
    Metric & US     All supported
    Heads up Display (HUD)     All supported     Performance varies on slower iPhone 3G or iPod touch 3rd generation and prior.
    Digital Compass     All supported     Requires GPS on iPhone 3G, 3GS and 4
    Altimeter     All supported     Requires GPS on iPhone 3G, 3GS and 4
    Check Engine (MIL)     All supported
    Shift Light     All supported
    Battery Voltage     All supported
    Fuel Level     See below *1*     New in version 1.5 of app.
    VIN Reader     See below *2*     New in version 1.5 of app.
    DTC Read & Erase     See below *3*     New in version 1.5 of app.
    gaugeface.com/features
  • hquick
    hquick
    That's VERY cool.
  • terroristone
    terroristone
    its a good thing, and it has ongoing development, i actually asked for AFR and they did it!
    T1
  • hquick
    hquick
    This would be ideal for mounting it.
    http://www.ourdeal.com.au/deal/waterproof-iphone-bike-mount-case-delivered-from-simply-wholesale/?ref=8Cv8V&utm_source=National%20-%20Daily%20Alert&utm_medium=Email&utm_term=Standard&utm_content=Side%20Deal&utm_campaign=OurDeal%20Daily%20Alert
