Online: Soapbox2627, softfat
Relay Problems
  • gordo68
    gordo68
     HI just wondering if anyone esle has had problems with relays. I have a 2010 dyna and have changed the two relays in the fuse box 4 to 5 times. One black and one light grey. I have had the bike since new and the dealer has been great in trying to fix the problem. Everytime we think it is fixed I get about 3000 to 4000 klms out of it and then the relays die and have to be changed. While we are waiting for an answer from Harley Tech as to what the problem is I thought I would put it out there to see if anyone has had the same experience and how they fixed it. Cheers
