Online: Soapbox2627, softfat
V&H Pro Pipe???
  • chrise1961
    chrise1961
     Anyone have any feedback on Vance & Hines 2 into 1 Pro Pipe Chrome or Pro Pipe BP exhausts?? My Bassani Road Rage scrapes badly when 2 up and the V&H pipes sit quite a bit higher so that should not be an issue, I am more interested in the performance and sound of the V&H pipes.
    Thanks muchly,
    Chris.
    I have never seen another Pro Pipe on a bike in Oz, but understand that I think Sporty Trace's hubby has one on his springer...
    1.  It is a huge pipe... photo below
    2. I have it on a near stock 2007 Street Bob
    3. I really like the sound, its very different... and heaps of others have commented that the sound is awesome.
    4. The jury is out on performance... because I changed a number of things and am not really the right person to comment
    5. It's not hard to scrape the pipe.. I have jacked the rear support up marginally, but still easy to scrape.... in fact most stock and after market pipes will scrape, especilly if you ride hard enough.
    did I mention... it's a huge pipe
    I purchased mine the month they were released... and the finish was crap and the heat shield was not available then. Just think it was not leaft long enough after being coated before being installed.
    overall happy except for size...
    where are you located?
  • fastapastor
    fastapastor
     Yeah Chris I got one on my Dyna. It's a bit lowered and you have to keep an eye on the pipe going around roundabouts depends how hard you go , it touches on the collector if you do touch.  It does touch when two up  but will touch at the end of the megaphone. Not too bad. I have heat exhaust wrap around mine all the way down and over the collector. So I cheat a bit and have put a couple or stainless hose clamps on at the collector so if it touches it touches on them and not rip the tape off. Lots of people who have the same pipe say mine sounds better. I have repacked the muffler with finer Colton wool style fiber glass plus the heat tape I thInk makes a big difference.
    Paul
  • fastapastor
    fastapastor
    Whoa sorry my phone just got the pic you posted. Mines the Indy outlaw style 2/1. Much shorter. Sorry.
    for those that are not aware, the Pro Pipe Chrome and Pro Pipe BP are different pipes
    Pro Pipe Chrome or  Pro Pipe Black
    Pro Pipe BP (Softie) of Pro Pipe HS (Dyna)
  • chrise1961
    chrise1961
    Thanks for your input Uncle Ho, I didn't realise how "huge" the pipe was and if it scrapes then that is a problem too, might have to look at another alternative I think, maybe the Pro Pipe BP???? I am at Glass House Mountains, the bottom end of the Sunshine Coast hinterland.
    Cheers,
    Chris.
