Online: Soapbox2627
finding stock pipes hard to find
  • hot dog
    hot dog
    hi every one . we got the sound laws inforced here in wa . hundred buck fine and bike has to go over the pits if over 94 db . the problem is i have tried to find out were i can get some stockers for my 92 softail custom . just in case i ever get stoped . does anybody know were you can get legal stock pipes from . cheers hot dog
  • Soapbox2627
    Soapbox2627
    Hot Dog, there is a thread somewhere on this forum where people with stock pipes will lend them for the purpose of EPA defects.
    a bit cheaper option and great support from fellow riders
  • FLSTC
    FLSTC
    Or , you can try fitting the pipes with tightly rolled up chicken wire, or similiar .  Keep the looks but quieter .
  • robots
    robots
    Hi,
    I tried my Local dealer (Geelong Harley) and they wanted to sell me some street bob pipes for $1700, i waited on the phone for 30min as she started counting and listing all these parts, I knew it wasnt going to be good
    perhaps HarleyHeaven if you could run a thread on what you have to clear out as I want to change tommy gun to a staggered dual like street bob or superglide for a 96ci, i reckon $200-$300 sounds about right
    thanks
    robots
  • Geoff3DMN
    Geoff3DMN
    The idea with the chicken mesh is not to get a permanent fix but to get a temporary reduction so that you can get a bike through a noise test. If you're going to go down that path then I'd suggest investing in a cheap sound meter from ebay so you can get an idea of what sound level you're actually getting.
