Online: patgreyling@hotmail.com, Hilly, speedzter
Backfiring Shovelhead.
  • Skullslapper
    Skullslapper
     Just started my 78 shovel and got blasted with a series of very loud backfires, she stalled and gave a puff of smoke out of the air filter. Bike was running like a dream 2 days ago. It will start but keeps backfiring. Any suggestions?
  • houli
    houli
    Condensor? if you still have points ignition, or points, ignition timimg, start by setting plug gap, timing. Check all wiring terminals. Won`t be anything to serious, swap ignition with a known working one if you get stuck.
    as houli say the condensor if you have points ign,    if it is you will have to clean the points or replace  them  +  best replace the spark plugs  as well
  • Skullslapper
    Skullslapper
     Thanks for the tips guys. I will be onto it asap. Cheers.
