Online: John.R
Fatbob to Lowrider
  • 78gold
    78gold
    Hi,
    Does anyone know if a fatbob (2008) seat will fit a lowrider (2006) as there is one on evilbay at moment.
    Mrs is after something a bit more comfy and I am looking at alternatives that dont take too much out of my mods budget. Was thinking of a riders seat with wider pillion detachable but bit too costly.
    Ride Safe
    Nigel
  • FatRob
    FatRob
    Most Dyna seats are quoted as fitting 2006+, so it should do.
    Where are you located?  There's probably someone with a FatBob near you that you can try the seat for size to make sure.
    FatRob
  • 78gold
    78gold
    Fatrob,
    I am in Sydney and will be heading near a dealer on thursday and will call and and check with them.
    Thanks for the reply, I thought dyna's might be the same.
    Ride Safe
    Nigel
  • 78gold
    78gold
    Thanks guys,
    Appears will fit without mods.
    Ride Safe All.
    Nigel
