Online: John.R
HD drag bars in black
  • ConR
    ConR
     Hey guys. Anyone know if the satin black drag bars match the matte black on the 2012 883?  Looking at getting a set.
    Appreciate any info!
  • slapster
    slapster
    The HD drag bar part 55800035 is same width as stock bar 30" & the same colour. Cost me $88.
    You may want to replace the front brake hose as it squashes up a bit due to the bar sitting a bit lower. HD do the Diamond Black 34" braided line part 41800178 about $107. Or go aftermarket.
    The LH grip can be a pain to remove, I sat mine in hot water to loosen the glue & it slid off with a bit of effort.
    Hope this helps.
    Slap.
  • ConR
    ConR
    Thanks for the info!
  • ConR
    ConR
    You running risers on yours?
  • slapster
    slapster
    Running the stock risers. All I changed was the bar.
    Slap.
    i got a set of flat bars BLACK chromed look cool, also on my 1974 sporty have a set of beadblasted alloy flat bars but every part on this bike is alloy  beadblasted
