Battery..
  • downtown
    downtown
    where's a good spot in Brisbane to buy a new battery?? for 07 sportster...
  • Will67
    Will67
     Buy a deka any battery place will have them
  • als1200
    als1200
    Any one tried a lithium battery yet?
  • 308bever
    308bever
    what are they Al? i read something on the old fartz forum about them being great for BMW, but costly...
  • als1200
    als1200
    Yeah costly for sure, don't know much of them but google away. I wonder if anyone has tried one in anything other than a battery drill! USA more than likely?
  • downtown
    downtown
    anyway, bought the deka from battery world, the bike has never kicked over so quick. Also found the missing side cover clip wedged on the other side of the battery!!!!
  • mikedsilva
    mikedsilva
    How much did that battery from battery world set you back?
    I used to dabble with RC planes and lithium batteries are quite the norm for me. I ordered some A123 cells from Hong Kong... 8 of them. I made a 4S2P pack but on full charge, it would only give me 3 starts before not having enough oomph. On a normal inline 4cyl bike (friends Kawasaki 636) it started perfectly every single time.
    The Harley has a high compression engine I guess, so needs more CCA to start reliably. I've ordered another 4 cells to make it a 4S 3P pack which should give PLENTY capacity and still result in a pack that is HALF the size.....
    The cells are on backorder so still waiting....
  • FatRob
    FatRob
     I think this would rule it out for me...
    (from the web site given)
    DOES THE BALLISITC PERFORMANCE COMPONENT BATTERY WORK WELL WITH A CONSTANT DRAW?
    The current product has been designed and developed as a starter battery in a powersports application. If there is a parasitic draw on your powersports vehicle (such as an alarm) we recommend that you disconnect the battery when not in use. If the battery is completely drained the cells can be damaged.
    FatRob
  • Will67
    Will67
     No idea Rob but they do list them for our bikes!
    But I have also heard they don't handle heat to well and most of our bikes the battery is located beside the oil tank..
  • downtown
    downtown
    anyhoo the battery was $189, didnt have time to find a cheaper one, but online have seen some for $159..
