Online: John.R, Merv
Switch off Alarm...
  • cm364352
    cm364352
    I think you would just need to punch in the security code.
    It pays to practice doing this a few times anyway so that you know how to if you ever nead to.
    WAZ...
  • Underground
    Underground
    I get it too.. not very often, but enough to get the sphincter working. I usually drop the bike on its side and run away like a little girl.
  • Daggs
    Daggs
    its all explained and easy to follow in your manual
  • Daggs
    Daggs
    ha ha good point Ho. I had to drag the manual out a while ago to learn how to do it when I had flat fob batteries, it is easy though.
  • Daggs
    Daggs
    That's fine unless the fob's battery is flat
  • V2Evo96
    V2Evo96
    Sometimes you can park the bike in an area where radio transmissions (or maybe aliens) block out the signal from either the FOB or the receiver. You better know how to use the code or be able to push the bike down the block to get out of the zone. Happened to me ina hotel parking lot near the Geelong hospital. talked to GHD service manager at the time who said it was a known area for blocking the signal.
  • Daggs
    Daggs
    I keep the cheat card in my wallet
