Online: HD17
Hidden Aerial for Street Glide
  • ozracer
    ozracer
    Hi all recently aquired a 2010 Street Glide and was wondering if anyone can point me in the right direction to acquire a hidden aerial so I can take off the aerial on the back of my bike and place it in the front bat wing fairing.
    There seems to be a number of these for sale in the us on ebay but Im not sure if they will work down under.
    Anyone got any pointers for that stealth look....
    Cheers,
    Adam
  • grahamjb
    grahamjb
    Guys
    Putting my Radio/Electronic Engineer hat on for this post, I can confirm that either of the above two hidden antennas will work better than the standard whip.
  • ozracer
    ozracer
    Thanks i bought the hd boom aerial 65 bucks
  • ozracer
    ozracer
    Peter stevens in adelaide
  • MESS
    MESS
    Where do you get those short rubber like antennas from?
  • ozracer
    ozracer
    Fitted the boom hidden aerial works great really happy with it......
  • ozracer
    ozracer
    No its a very straight forward job aerial mounts to inner fairing with double sided tape and zip ties very easy all supplied. I used it in the country and reception was good there too.
    Highly recommended.
