Online: beaglebasher
Joker Machine Sportster speedo side mount with LEDs
  • 45WL
    45WL
    I've been looking at the Joker Machine speedo side mount with LEDs
    http://www.jokermachine.com/itemstreet2004.asp?ItemID=636&CategoryID=92&Placeholder=0
    The product description states that it is only for 2004 and up, why is this? would it not fit on a 96 model? If it is voltage issue as the old bike still use bulbs and not LEDs could I not introduce a resistor to protect the LEDs in the assembly?
    Any advice appreciated
    45wl
  • terroristone
    terroristone
    maybe fork diameter? 39mm? stock speedo size? shoot them an email and ask.
    T1
  • 45WL
    45WL
     Thanks T1 & hmmm
    Got this reply from JM:
    "It's a wiring issues. You have 10 wires and ours only has 7. You can make it work but you'll have to splice some wires together. I have something I can send you that will help you wire it."
    Hmmm did you have to splice anything and add resistors to protect the LEDs?
  • slapster
    slapster
    45WL have you considered the Autometer 3209 bracket to relocate your speedo? Much cheaper option, then all you have to do is sort the bar clamp & idiot lights.
    Slap.
  • 45WL
    45WL
     Thanks Slap
    Cant see how its fixed to the bike? fixed to the frame or fork? WAY CHEAPER OPTION ;-)
  • 45WL
    45WL
    Thanks hmmm - so no resistors, just soldered the wires . sounds easy enough.
    Thanks Ozroder for the heads up - cant do bloody anything now days!! but I'm still going to give it a go LOL!
