Online: beaglebasher
Removing Ape Hangers
  • PK2
    PK2
    Not a big job, and you'll get that sense of satisfaction when you're done! Probably only help you'll need is bleeding the front brake when you put the old brake line on. If you're going flat bars, you're probably better off getting a shorter braided line while you're going. Mine is 800mm plus fittings
  • Ross
    Ross
    Definitely read the manual, there is a sporty manual floating around in here somewhere if you do a search if you haven't got one. Makes the small things simple.
  • terroristone
    terroristone
    if you get stuck let us know mate,
    Have you still got the stock rubber grips on the apes?
  • terroristone
    terroristone
    because the left grip is glued on from factory and there is an easy way to remove it without damaging it....but that dosnt apply here.
    T1
