my build
  • robots
    robots
     Hi,
    Keep us updated with photos please mman, always like to see pics of the best bike in Harley's lineup
    Thanks
    Robots
  • Ando
    Ando
    whats wrong with the 777 cams ?????
  • Ando
    Ando
    I would put them in with a .030" headgasket
    I think you will be supprised,,,,,,,,,,,, hey if ya don't like them after ya try them rippem out
    Another vote for staying with the 777.
    Nice cam.
    Perfect time to do it properly and pull the heads for a tweek.
    OK, here's the thing, what I would do is just bolt the 777's in for now, and ride it for a while.
    They will work OK with stock CR, and should give you a nice mid/upper boost with a good tune.
    If you are looking for more, the 777 is perfect for upgrading the heads, and while the heads are
    off, you REALLY MUST take it out to 103/107, as you are 9/10ths there anyway.
    Easy !!
    Hey, I'm trying to save you money !
    The second part is optional, and can wait until/If you are ready.
    Plus, it looks like you dont mind spending a $$ or two on your hobby !
    What is it with all the vanishing acts around here ??
    What Oil cooler set up did you go for ?
    I'm waiting on a set of TW8's from FM as well ! Gave up on Tman for now
    At 40k , I would be changing lifters.
    I'm currently using comp Cams 850-1 lifters now, and they work well, and are a good price.
    For my 113" Motor I have a set of their 875-1 travel limited lifters.
  • Will67
    Will67
     add some pics as you go mulletmun makes the thread more interesting!!!!!!!!!
     Lookin good so far. Some nice expensive bits you have on it. What else would you spend your hard earned on eh.
