Online: Merv
XR1200X caliper and braided line
  • PK2
    PK2
    Fitted the XR1200X caliper onto my Iron yesterday, and braided brake line. Caliper bolted straight up, no mods needed. Got the brake line from motorcycleracegear.com.au which is a HEL line.
    Havent been for a big ride yet as it was drizzling when I finished, but the 100mts I did up the street shows a huge difference in braking and feel - very happy!
    Will post more after I've been for a decent ride (hopefully Tuesday)
  • terroristone
    terroristone
    I'm keen to hear more PK, its been on my list of things to do for some time now. Also i have seen a few threads on the net where they needed to mill some off the inside as it would just touch the rim when turning (all wheels will have some flex) and put small marks all the way around.
    T1
  • Bartikus
    Bartikus
    I've got mine in the shop getting done now, as well as the 1200 conversion,cams and a dyno. Put the braided lines on a few months ago which helped but hoping the calipers will do the trick, I'll let ya's know how it goes.
  • PK2
    PK2
    T1 apparently the later Irons have to mill a fraction off (less than a mm), not sure what the difference is but mines a 2010 and bolted straight up with no issue at all.
  • Iron Eddie
    Iron Eddie
     Not sure if you've seen this link but there's a thread running on the XR caliper, http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=1&postid=275005&view=topic, have a read of my post (with pictures) for clearance issues.  I tried to put descriptive info beneath each picture so others could understand the issues with alloy wheels.  Fitment is an easy job, just check the clearance as noted between spoke and caliper before you ride (unlike me, I found out after rotating the wheel) and you'll be stoked!!!!
    I read the other comments too and this helped (after I ballsed up the inital fitment).   It's like the old carpenter trick measure twice cut once, I should have read twice....
    Comments from others helped me and this site was good to use, so good luck to you.
    IE
  • terroristone
    terroristone
    what part number was your caliper PK?
    T1
  • PK2
    PK2
    T1 the box has 42943-08 which is LH front from Xr1200x. I just asked Sam at hh ringwood. Braided line was from motorcycleracegear.com.au Alex supplied sensational service, and was $80 delivered. Banjo fittings at both ends are 10mm. mine was 800mm, yours would be a fair bit longer!!
  • terroristone
    terroristone
    I'll only need the caliper for mine, as i already have the braided lines...what did the caliper cost you?
    T1
  • PK2
    PK2
    210 delivered from Sam hh ringwood on the parts for sale section of the forum
  • 48fan
    48fan
    if sam quoted 210 ,you will probably get em cheaper at another store
    just sayin
  • PK2
    PK2
    Jase I was happy with that!
  • mikedsilva
    mikedsilva
    does the caliper come with pads?
    will the stock line mount up to the new caliper?
  • PK2
    PK2
    The only thing to check is that the caliper clears the spokes. Apparently some later models will touch slightly. Just check before you go riding!
    Go the braided line later on, you won't regret it!
  • Viob
    Viob
    Hi guys,
    Just a question about the braided lines. Want to fit HD drag bar without risers and XR calliper on a 2011 48. Are the HD lines 41800178, One Piece - 34" the right ones? 34" should be around 800mm.
    Cheers,
    Peter
  • terroristone
    terroristone
    Pete, use a piece of string cut to 34" and use it to work out if it will be too long/short!
    T1
  • PK2
    PK2
    My braided line is 800mm with a broomstick bar
  • animall
    animall
    When I fitted my caliper it went strait on and missed the spokes after a30 min blast on a very twisty range hard braking every 20 - 30 seconds or so the caliper expanded with the heat and then started rubbing the spokes . A long ride home without using the front brake , got home tapered off the bottom edge of the caliper now no probs . Just be carefull for first ride if lots of heavy braking , ride safe
  • PK2
    PK2
    Yeah apparently the later models are a fraction closer to the rim, mines a 2010 and I've had no issues.
    Don't know what's changed over the 2years?
