Online: evo94
iron- ss brake line kit
  • animall
    animall
    hi guys, am looking for stainless brake line kit for my iron , whos running them ? where did you buy and how much you pay ? found lots of unknown to me brands on linefrom usa  but want a name i can trust & adr approoved  ,ie goodridge , HEL ,etc any one help ? cheers guys
  • PK2
    PK2
    Just received mine today, hopefully put it on on the weekend. Black HEL front braided line I received from Motorcycleracegear.com.au today. I ordered an 800mm line as I run broomstick bar so it's shorter. Great service, just under $80 delivered with one straight and one 45 degree angle banjo fitting plus bolts and washers.
    Was going to put a posting in the workshop section after I fit it
  • animall
    animall
    thanks for that will be buying mine from there , just priced up brand new xr 1200 caliper $ 233 from dealer make a very cheap brake upgrade
  • PK2
    PK2
    Get onto Sam at hh, think I paid 210 Inc delivery, and they come with the pads.
  • slapster
    slapster
    HD do the Diamond Black braided line part.41800178 about $107. That part will fit your Iron out of the box.
    Slap.
  • animall
    animall
    just found online brand new xr 1200 calipper, lh, part no HD42943-08 , at newcastle hd for $145.74
  • PK2
    PK2
    That's alright! With pads?
    I had to get a shorter brake line cause of my broomstick bar.
  • animall
    animall
    the hd part no comes up at dealer including pads
  • animall
    animall
    oops !! so i do , well spoted , did'nt look at the whole address . not that cheap when you add shipping . must read things better , lmao
  • PK2
    PK2
    The braided line I got had a larger banjo at the master cylinder but needs to be the same size as the caliper end. That's unless HD changed the master cylinder on the later model Irons. Got it to seal ok, but just so you know when you order. I'll be letting motorcyeracegear.com.au know for future reference.
    Got it fitted yesterday, unfortunately drizzling when I finished so I've only ridden it for 100 meters, first impression is unreal! Caliper bolted straight up.
  • animall
    animall
    The 2012 model should have 10 mm banjo both ends
  • PK2
    PK2
    yep, and the one at the caliper is a 45 degree angle.
