Master cylinder honing
  • Burnzi
    Burnzi
    Just rang 2 bike service shops to see if I could get my brake master cylinder honed, "Nah mate we send them to XXXXXXX engineering and he does them for us"
    So I ring xxxxxxxxxxxx engineering and he says " no too small we cant do them"
    Anyone got any tips on a home honing job?
    Thinking about a bit of emery on some tube?
    EDIT: the smallest the local auto shops sell is a 11/16, need 5/8
    If using a 5/8" Dowel (Steel) use with very fine grinding paste and oil.
    If using wooden rod, put slit in the rod and use Wet and Dry with kero in a drill chuck.
    Don't use Emery cloth way to abrasive...........
  • russ4570
    russ4570
    If its only very light scoring or corrosion you can also use some 000or 0000 steel wool. On the dowl or by hand. I usually use the wet and dry with a good lube ,kero is the best for ally as mentioned above. Last method is old worn out scotch brite on a dowl rod.
    Good luck and let us know what you went with.
    Regards
  • phil01
    phil01
    Is it cast iron or alloy
  • Burnzi
    Burnzi
    It will be alloy and probably doesnt need much, had a slight drip from the plunger and couldnt get a hard pedal. Ordered a new kit for it and figure it could do with a light hone.
  • Retroman
    Mate, sorry this is late in the piece, but you can buy a young "take-off" master cylinder from ebay for cheap money.
    I was bidding on a 2009 rear master cylinder just last week and missed it at $85 Australian ! In Qld as well !
    I only wanted it for the shed, didn't "need" it just now
    These are all from guys who "chrome-out" their bikes soon after or even before delivery
    Fronts go for much the same money.
    Depending on time you have, the wait can be a pain , that's the way to go
  • phil01
    phil01
    Alloy cylinders are not to be honed
    They have a coating because alloy is porus
    Just replace it mate n dont fark around
  • phil01
    phil01
    You can get it sleeved instainless steel -
    It may have been already ?
    Guys bad practise honing alloy
  • houli
    houli
    Have always taken mine to a brake repairer to have them sleeved in stainless, a hone will only change surface finish not contour, ie if its worn oval it will stay oval.
  • phil01
    phil01
    If your in sa take to power brakes for
    A sleeve
    If your elsewhere some 1 will direct
    I am well qualified for advice above..
  • Sparra
    Sparra
    I just ordered one off ebay for $71.00 delivered for my 1995 softy...
  • Burnzi
    Burnzi
    Managed to buy a 13mm up hone but wont be doing anything until I see what the bore is, ie: stainless lined or original alloy. Having trouble removing the nylon/plastic plug behind the circlip, will try with compessed air tomorrow to get plug out and assess next move from there.
    Thanks for all the advice, very helpful. Have rebuilt HQ brakes, 40 series Landcruiser (with FJ55 brakes-253V8 compliant) and a multitude of trailers. Bike brakes are new to me.
  • russ4570
    russ4570
    Arhuh, now your talking. I had a shorty 40 as well. I reckon the japs had a challengs to see how many cylinders and seals they could stuff into one vehicle. The guy that designed the 40 series wins hands down.
    Brake repair specialists dream car.
  • Burnzi
    Burnzi
    Okay a bit of air pressure got the white nylon plug out and lo and behold one knackered "o"ring seal thingy. (the rear one) Had a good close look at the bore and everything looks fine. So in with the replacement master cylinder piston after a good clean of the bore with air and tissues and more air and a spray of crc and more air. Used an autobarn brake cylinder bleeder and got pressure up beautifully, no leaks and nice and firm (just how youd like a boob job really) So the 13mm hone is sitting in its wrapper bemoaning its existence. Will re-bleed after a good ride and top up if necessary. Thanks all for your advice, the brake bleeder was fantastic truly a one man job, simple to use and efficient and about $15.00 I think.
    Anyone want to buy a as new 13mm up brake cylinder hone??
  • phil01
    phil01
    Next time no crc.
    Just brake fluid.
  • phil01
    phil01
    Next time no crc.
    Just brake fluid.
  • phil01
    phil01
    Next time no crc.
    Just brake fluid.
  • Burnzi
    Burnzi
    OK OK no crc, I get it already, sheesh
