Online: Soapbox2627, softfat
Exhaust help please
  • Maxiboy
    Maxiboy
    Hello there learned collegues.
    Can you tell me if slip ons designed for the 2010 Fatbot will fit on a 2011 Deluxe. I can't see any difference but the guide says they dont. Does anyone know better?
    Thanks in advance
  • ozymax
    ozymax
    maybe mounting points are the issue
  • KiwiRob
    KiwiRob
    The Fatboy mufflers are quite different @ the point @ where they slip on to the exhaust head pipes. The exhaust cross over/balance pipe is part of the complete muffler, where as the Deluxe cross over/balance pipe is part of the exhaust head pipes.
    If you saw the Fatboy exhaust without the head shields you would see how different they are.
    Rob
  • Maxiboy
    Maxiboy
    Thanks heaps KiwiRob.
