no fuel pump with thunder max
  • jim76
    jim76
    Gday all spent the morn fitting my thunder max to the bike went n did the key on /key off start twice for 10 seconds then warmed it up to about 260degrees. all was well i thought.the last thing i did was load the firmware software saved my maps n thought u rippa time for a ride. come out to start bike but no fuel pump bike turns over but no prime. i thin k i have stuffed up with the firmware download i read the pdf file it says after frimware download to write n save maps i dont think i did this it all so says there can be issues if not done proply. so im a bit stuck i tryed to load all again still no fuel pump. pulled thunder max out n put stranded ECM back in now i have a fuel pump can any one help me out i all so have a flat battary now will have to put it in the charger
  • jim76
    jim76
    i will recheck that when i loaded the base map it was set at one that was with the smartlink update. will let u no how i get along
  • jim76
    jim76
    just went n plugged computer back into bike sure enough the main relay lock is set at 2 but i cant change it  .this must have happend when i did the firmware upgrade cause bike was running fine. Any way i cked the map i put into thunder max it says 1 i will have to reload a new map to correct the problem many thanks scotty your a legend
  • Peter
    Peter
    Thats what happens when you get to 1000 posts.
  • jim76
    jim76
    yeah started with the basics cked all my fuses had a test light had no power at all going into fuse thats when i pluged in the ECM (standed) i then had a fuel pump working so i had a feeling it was something to do with the updates i did with the firmware. its all good now
