cranks but wont fire
  • hogpooh
    hogpooh
     My 07 fxstc sometimes cranks but wont fire. Got it to dealer but now it starts everytime so dealer cant find anything wrong. I told him replace coil but think i'm guessing too much. Ideas?
    PS No codes came up when it didnt fire so assuming its not a sensor.
  • Toto_jp
    Toto_jp
    Check the battery voltage might be showing signs of dying especially when its cold, I had problem on the weekend cranked over strongly
    but refused to fire voltage was 12.9 volt put on charger for an hour 14.4 volt and fired up straight away .
    cheers Tony
  • hogpooh
    hogpooh
    Thanks Tony. Forgot to mention that i keep a trickle charger on it so thinking that shouldnt be problem. Though it is original battery
  • Slippery1
    Slippery1
    Have a close inspection under the seat for a loose earth wire. I have a aftermarket tuner and the earth wire was loose and symptoms were the same until I found and tightened it.
  • hogpooh
    hogpooh
    Have replaced coil. So far so good in two days. Still got doubts that was problem
  • phil01
    phil01
    Eliminate battery by jump start.
    Thats step 1
