G'day stoned pirate,
To pass EPA requirements harleys run lean. Installing freer flowing flowing exhaust and/or air fiter And it can lean the mixture out even more. Whether engine is run in or not makes no difference. The bikes efi unit can adjust to a certain degree and your bike may be running ok. It would be best to install a tuner or even the most basic of devices the XIED from www.nightrider.com can enrichen the mixture in closed loop But if you want really release some power the are plenty of tuners to select from.
It's only money
Regards,
marx
?Engines are "run in"
Horses and virgin's are "broken in"
Anyway it would be better to run it in with the good stuff fitted
And dont nurse it ,run it in how you are going to ride it.
Just avoid high revs for a while and dont over rev it at any time ,especially when down shifting.
Stewy
Found this about running motors in,
Interesting reading, his views are a bit different..............
http://www.mototuneusa.com/break_in_secrets.htm
I also agree 100% with him. I use something very close to his dyno break-in.
"Running in" just sounds much better, or closer to what is really going on.
