Fatbob guard on a Wide Glide
  • Harley_Dude
    Harley_Dude
    Has anyone tried to put a late model Fatbob (dovtail) guard on a Wide Glide, or the opposite. Do they fit witout modification?
    Also, does anything else need to go with it. I know the brake light would but would any of the wiring loom also need to go, or anything else? Would the rear strut arm covers also be interchangable?
    If so, does anyone have a gloss black guard in perfect nick, brake light, and chrome stut covers (for my black ones) they would like to swap off my 2012 Wide Glide? If so pm me.
  • dyna gliding
    dyna gliding
    have a look at this
    http://www.hdforums.com/forum/dyna-glide-models/428316-wide-glide-rear-fender-onto-a-fat-bob.html
  • Harley_Dude
    Harley_Dude
    Thanks dyna gliding and sdeepdz.
    Both bit of info have been very halpful. It looks like this can all be done with just some minor rewiring. Now I just need to find someone who would like to swap parts. All the other posts I have read on styling about guards suggests that the chopped fender off my bike is more popular then that older looking ddove tail guard so I am hopefull.
    Again, thanks for your help.
  • Harley_Dude
    Harley_Dude
    Still trying to swap wide glide chopped fender for a fat bob botail one.... any takers?
  • WEBBY65
    WEBBY65
  • Harley_Dude
    Harley_Dude
    That looks shit hot mate! Much to it?
  • WEBBY65
    WEBBY65
    I paid them $!.000 they did it all
  • Harley_Dude
    Harley_Dude
    Was that at Perth HD, or Frasers?
    Perth HD are the cheapest I found so far at $1500....
  • linmac
    linmac
    yes it fits ive just done mine you will need to change the wiring harness and the metal struts that run along the guard are longer than the wide glide guard
  • linmac
    linmac
    After Fat Bob guard fitted
  • linmac
    linmac
