Online: beaglebasher
Shovelhead remote spin-on oil filter brands
  • jackal
    jackal
    Im looking around for an automotive oil filter to fir the specs required for a shovel engine (ie 30 microns, 8-11 psi bypass, 3/4 - 16 thread).  Now where I live its a pain to get stuff that isnt the generic - like Bosch.  So my question is, is anyone using Ryco oil filters such as the z158 or the like?
    What other brands are you using that is easily available through the various auto stores?
    Cheers,
  • jackal
    jackal
    Hi Kiwi - I know what you mean about the risk, thats why I am asking around. I have read lots on other forums with people finding 30micron filters, with 8-12psi bypass that are mean for the older cars.  So thats what im trying to find out with Ryco.  I actually send Ryco an email with my specs to see what they got.  Worst case scenario ill order the appropriate Bosch/Wix type filter off egay.
    Thanks for you reply you, appreciate it.
    Cheers,
  • The Don
    The Don
     Hi Jackal,
    This is taken from a US site:
    These Oil Filters
    have 3/4" x 16tpi threads,
    8 psi by-pass valve,
    anti-drain back valve.
    The ones in blue are recommended
    • Purolator PL10241 / PL25230
    • Mobil1 M1-102
    • Bosch 3330 / 3421 is longer
    • AMSOil SMF 133/134/135
    • Baldwin B1413
    • Fram PH6022, PH6065A
    • Hastings LF576
    • NAPA 1348
    • Purolator ML16822
               and the one I use for my 89 Evo is  WIX 51348 .
    Cheers,
    Cris
  • jackal
    jackal
    Thanks Don.
  • jackal
    jackal
    Just to finish off this thread, I ended up buying the K&N KN170 oil filter which I can get locally.  But DAMN are they expensive!  Still I want engine protection of course ;)
