Online: beaglebasher
timkin bearing mod & crank upgrade
  • Outlaw01
    Outlaw01
     Im looking at doing my engine up further but I cant seem to find anyone that can modify the cases to take the timkin bearings & true , balance & weld the crank.
    Anyone got any ideas?????????
    Ollie's  Eng , Qld ,  about the only  bloke around
  • Outlaw01
    Outlaw01
     Have you got any contact details for him?
    In Sydney Cow @ L A Cycles, does timkin conversions, & he welded my Crank very happy with results too as have reved this motor to  7,200 regular  it's smooth.
  • ozymax
    ozymax
    well then they may lift their game
    Just pulled the trigger on a new set of SE Case's that will have the Timken conversion done by Darkhorse, along with a new
    lightened Stroker Crank' bult by them using S&S parts.
    Should be a solid bottom end.
    Ollie's in Qld   OEM   & John Tresse Eng  TRE in Vic  are about the only 2 that can do the late style  press together cranks  as far as i know Ollie gets a lot of work from a lot of shops  , Robbo's harley etc
    Krash, I was looking at a complete S&S 124, but that would have been expensive,
    So after lots of thought I've settled on a 4 3/8 stroke and 4.060 bore using SE Cases/Cylinders and Headquarters CP dished Pistons .
    I have a set of WFO Larry stage 2+ Heads that I was going to use on the 95" engine.
    I could have gone to120 or 124 for not much more $, but I'm planning on somethng that will Rev a bit quicker with the lightened Crank, and be bulletproof.
    I was almost going to use 117 Axtell Cylinders, but I've read to many horror stories about them suffering poor ring sealing due to going out of round.
    And I'm not a big fan of overboring cases that far, along with base gasket problems.
    It will be around 10.5:1 with 84cc heads, and I'm looking at using Tman TR590 Cams.
    There have been a lot of very strong 113 builds I've seen in the US, so here's hoping !!
     i only use the 80,000 lbs tuctile iron type  AXTELL  barrels  iv'e never use the aluminium style  do the alloy one's have problems ?
    Krash, I'm leaning towards a 45mm Mikuni. I think a 48 would be overkill, and makes manifold choice harder.
    The Alloy Axtell with Iron liner have had problems I've read.
    hi, i think i replied  before on too high comp ratio on the wrong choice cam's with working on more low down & mid range torque to pull a heavy  weight bike + a heavy rider  &  even 2up ,     the earlier the lobe centre  esp on the inlet the more prone  too pinking or detonation the more load you put on the crank & bigend @ lower rev's  when the motor does not get a chance too rev up  too take the load easier  esp on the later model longer stroke crank's  = more load  ,  these motors will rev to 6,000 rpm without hurting them there good working range is from 2,300 -4,800  in normal riding , the more you   lug the motor  & load   lower rev range  the worse it is , if you want to go fast rev her out a bit in 3rd gear 4th etc , get thru 1st & 2 nd as fast as posible  as the lower gears do not take you  very far  or fast  & is easy to over rev the engine
  • Ricca
    Ricca
    6 years ago
    Quoting speedzter on 10 Jun 2012 10:24 AM
    Been a few years wondering if you are happy with the darkhorse crank ?
    Looking at doing a set up for my 07 train , Supercharged,
    Blew my oil pump due to bad crank run out now looking at a setup to be strong and affordable
    Whats a Welded crank rated to in everyone's eyes.
    Im pushing (was) 160+ hp
    Looking at Darkhorse Man o war set up with T man 107 performance kit and fueling cam & oil plate set up
    should be a winner! here for suggestions
  • Baloffski
    Baloffski
    6 years ago
    Wellllll. That was a long time between drinks..?
    Mr. Hood of course nailed it.
    6 years ago
    Quoting Ricca on 08 Mar 2019 06:24 PM
    Funny (expensive) story, that DH crank chewed out the rods very early, was sent back to the US and they rebuilt it under warranty.
    Never really found a cause !
    With the new import costs, freight costs, and aussie $, I would just buy an off the shelf S&S Crank.
    About $2200 last I checked, and that is what I did with my current 120 that I built.
    Also the current S&S have changed to a 3 piece design with a 1.675" pin.
    No welding needed (or recommended by S&S ), and I used SE Lefty bearings on both sides.
    I will only ever be in the 140hp range, and wont do high km's, so didn't warrant a Timken conversion in my opinion.
    Welding itself does little for Crankshaft strength, the best way to increase crank pin fit/strength is to fit an oversize plug or "pro plug" as DH call it.
    The Timken upgrade is another bone of contention for me.
    To do the upgrade correctly, you need more than the simple "bolt in" adapter from Jims or SE.
    Maybe I'm overthinking it, and Hoody would have more experience with this.
    Check out how Tman or DH do it.
    A new 3 piece off the shelf S&S Crank will handle 160hp +
