Sportster SUPERLOW
  • 308bever
    308bever
    why bother? it is what it is, if other`s think it`s a girl`s bike, why care, mine`s an 883, so what? lol, enjoy it (((-:
  • chriso
    chriso
    you could put a 1550 one on.....no one would know the diff
  • wildkatze69
    wildkatze69
     If it's the plate on the air filter you are talking about there are loads of options of replacement plates; skulls, sportster logo etc.
    Takes a minute to change.
  • wildkatze69
    wildkatze69
    I got a complete new air cleaner on mine. With new, other then stock pipes you also need a tuner. Bit of $s in that.
    If you only want get rid of the trim saying 883, you can actually just take it off and leave it. Then there are loads of decorative 'air cleaner trims' available to put on. Go to your local dealer and have a look. And when there don't forget the accessories catalogue and check out p.502 onwards.
  • FatRob
    FatRob
     Hey Lucky T,
    If you look here at part number 7 you will see that you can get a different insert for the various models in the Sportster range.
    www.jerseyh-d.com/Components.aspx
    I don't suggest for a moment that you order from these people as they are expensive, in my opinion, but it will give you the part number.
    FatRob.
