defect - wrong rego #
  • Highly Sprung
    Highly Sprung
     Hi,
    I was issued with a self clearing Defect notice for my Handlebars in Qld last weekend by Task force Hydra. They had the road blocked off and singled out motorcycles only. Issuing numerous fines and defects. The officer (hmmm) has reversed the first two letters of my rego plate ( KX instead of XK ).
    Does this make it invalid ?
    If I dont ammend, does the owner of the rego # KX --- have his rego cancelled ?
    Any info will be appreciated
  • fattatt
    fattatt
    Welcome Enjoy.
  • Pastrypete
    Pastrypete
    Welcome...didn't they also get your license number?
  • Pastrypete
    Pastrypete
    How the hell do you get a defect for handlebars?
  • Highly Sprung
    Highly Sprung
     thanks, that might be the go.
  • ozymax
    ozymax
    in all likely hood they also noted your license number, name, address and vehicle details on the notice. Challenged in court could have a finding of a mistake of recording and not an error of fact.
    It's a self clearing defect so buy that I think you simply need to correct it and have it signed off. I am guessing it was for apps.
    as mentioned above phone transport and ask but dont put yourself into further drama over a defect you can correct and move on.
    Good luck
  • mumbles
    mumbles
    In NSW 98cm wide max
    And I think bars above the shoulders are defect.
    I might be wrong?
    I would have thought they took your licence number.
