So any help would be appreciated........" /> So any help would be appreciated........" />
How to bring up ERRORS
  • Finny
    Finny
     Can someone please help me out, I have forgotten how to bring up errors on the speedo.
    I have a 2005 ultra glide that is reving its tits off.
    On start up she sits on 2000 revs, then starts to lower < gets="" to="" 1500="" then="" starts="" to="" build="" up="" again="">
  • taff60
    taff60
    Ignition off. Press and hold speedo reset. Switch on ignition. Speedo needle should move and ur now in code mode.
    move through the modules by pressing the reset.
    press and hold..........code is displayed. Press and hold again and code should clear.
    swtch off ignition to exit.
    There is a good list of codes on this site
  • Finny
    Finny
     Thnx Mate
  • Burnzi
    Burnzi
    Sorry I thought this was gunna be about how to bring up ya kids!!
    Reading codes
    ________________________________________
    The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
    1- Ignition off
    2- push odometer reset button in & hold. Make sure run switch is on.
    3- turn ignition to run and release button (you will see P, S &C displayed)
    4- each letter represents an area of diagnostics... the one that is flashing is the one you are going to check. To move from one letter to the next, you push the button one time. (from P to S to C and back to P, etc.)
    5- to get DTC within an area, you push and hold the button in for 5 seconds and if there are any, it will be displayed... you can release the button. As you push the button again, other codes will appear if they are there. If there are not any the word 'none' appears.
    6- Record the codes.
    7- To determine if a code is current or historic, you clear the codes while being displayed by pushing in and holding the button until 'clear' comes up. Turn off the ignition... then crank or restart the bike... turn off, and then repeat the code process. If a code is there now, its current... if not, it was historic.
    I believe that the key must be in the run position and the handlebar switch in the run position to read the "P" codes. Otherwise you get a "noresp" message.
  • Finny
    Finny
     Well i found a Fault...ERROR......P0505... Loss of idle control, Checked all conection as it says to do, Tried to clear error but Keeps coming back. could it be a AIR leak ???? or is it a trip to the HOG Doctors....?
    And thnx for ya help with bringing up the code....
    Cheers FINNY
  • taff60
    taff60
    Check that the idle control valve isnt unplugged or loose. With the bike off, pull the plug and give it a spray with WD40 water repellant. Try it again. If not, it may be a stealer job to replace the IAC.
    Good luck
  • Finny
    Finny
    Cheers Bloke, I'LL have a look
