Online: tussuck
Black Engine
  • Bloodnut
    Bloodnut
     The black paint on my engine, seems to be fading a bit, do any of you guys out there cyberspace, know of a product I can use to restore it a bit?
    Besides repainting engine.
    Cheers bloodnut
  • ozymax
    ozymax
    if it is smooth finish I just use turtle wax now and then. If it's the wrinkle finish I have NFI
  • Fr3d
    Fr3d
    I use cheap tyre shine from KMart. Clean the motor, when dry spray on and wipe off. Lasts a while. I have been doing it for years and have not had any problems. The motor comes up like new
  • Hound_Dog
    Hound_Dog
    Mr Sheen
  • Bloodnut
    Bloodnut
     How does Mr Sheen cope with engine tempreture?
    Cheers Bloodnut
  • AJ56
    AJ56
    Engine Shine. ( Picked a can up from HH once and it is actually pretty good stuff. About 15 bucks for a spray can.
  • Train
    Train
    $2 tyre shine
  • Granox
    Granox
    Use the tyre black you get in tins I use it all the time on mine works great
  • Bloodnut
    Bloodnut
    Just tried tyreshine, works a treat, thanks for input guys.
    Cheers Bloodnut
