48 mirrors
  • watto883
    watto883
     Just thought i see if any of you guys had a stock set of black mirrors off a 48 for sale ..... Cheers Paul
    want the short stem ones .... not sure what other model they came on BUT think with 48 ones the writing on them be up the right way as they are flipped from the factory ????
  • TC883
    TC883
    Watto, the Iron mirrors are the same as the 48 mirrors, only the writing is the other way up. The Iron does not have flipped mirrors from the factory. Apart from the writing, they are the same. Hope this helps you with more options. TC
