Online: Wanderer57
replacement 2012 s/glide tyres
    Has anyone fitted non genuine front and rear tyres to 2010-2012 street glide, what did you fit and cost?
    Any one???? Or do you ride on the rims when the tyres are fucked?
    Not there yet , 5500kms , what mileage did you get from originals ?
  • Will67
    Will67
     Do a search in the search option on tyres pages and pages come up.
    15500klm with the last 7000 klm done over three weeks fully loaded going from Sunshine coast Qld, over the snowy mtns, great ocean road, adelaide then home. Had pissing rain, minus 6degrees, and 30 degree days and no slides or nasty moments. Would fit standards again but looking for options as they are NOT CHEAP!
    Ta, problem is the 2012 s/glide has strange fitment sizes giving you only a few options of matched sets rather than say a michelin rear and dunlop front. Std replacement Not CHEAP as well!
    Ta, good site, have you bought from them?
    $250 U.S. for a pair of Michelen commander 2 . Don,t know how much to freight , + fitting .
    Good price but they dont fit in the std sizes that come on the bike. Would have to change aspect ratio of tire to use them
    Standard front size 100/90-19 57H , standard rear size 160/70-17 73V .Michelin Commander 2 have these sizes . If you can believe ads 40k tyre life ?
    Sorry Tim we are on different pages here, a 2012 street glide has 130/70/18 front (not available in michelin commander) and a 180/65/16 rear (available in commander) so as previously stated without splitting brands there are not many same brand options other than std.
    Ah yes , s/glide meaning street glide as opposed to superglide , no worries , good luck .
  • Gilesie
    Gilesie
    Yes I have brought off them, good service and fast turn around with fedex, tracking all the way
