Online: obisteve, clackavosticus
s&s 106
  • Glider
    Glider
    Hi Mulletman, just finished doing the 106 upgrade, installed 585 ezi starts and just did a clean up on my original heads.
    Also had to fit a SE heavy duty clutch spring, had a bit of slippage when I gave it a handfull.
    All good now. are you doing the work yourself or through a dealer?.
    Do you live in Sydney, feel free to call me 0411883282
  • fastapastor
    fastapastor
    I just did the same upgrade but upgraded my stock heads. Port job and bigger valves and new springs etc i used the 585c I just used the chain type cams as they have no issue with the tensioner these days so I saved money. Awsome power. Went from running 12.6 to 11.5s. My engine builder came to the track and has been mucking around with the tune using the laptop with the power commander plug in. i also just upgraded the clutch sping. I need to get the money together to get a full dyno day. I know it will go better. If I was just using my bike for street work I would probably go the 525 cams.
  • Outlaw01
    Outlaw01
    Id stay away from the ezi start cams they do have issues with the decompresser tab
  • Ando
    Ando
    S&S is top quality gear, I had the 106ci pistons and barrels with the 54h cams and heads ported in States for the cam
    it ripped a mates 106 with 585 cams
    them 585 cams have a bit big duration and are soft if ya haven't got enough compressionand easy starts have stuff that cam go south with them
