Online: Merv
113 kit
  • wooleybull
    wooleybull
    Hi people my 2012 fatboy is in the shop with an oil leak, thay said i could upgrade to the 113 kit with a small labour charge for machining, $3,500 for the upgrade kit. My question can i import the kit cheaper and most importantly is it worth it
    cheers Michael
    What's included in the 113 kit ? Is it cylinders and pistons and Cams ? I take it yours is a 103 now ?
    Sounds like a good deal. To do it with parts from the US, the labour cost to reamove and tear down the motor for maching would be expensive.
    They must be covering most of that under warranty for the leak ??
  • simmac18
    simmac18
    Have a look at the screaming eagle catalogue this is whats included freight will get it close make sure this is whats on offer bloody good kit for the dollar
    a. screamin’ eagle® Pro stage iV race Kit –
    113 cuBic inches
    3
    A complete kit for the racing performance enthusiast. this
    kit has it all to get your motor to perform competitively at
    the track. this kit includes our precision honed big bore
    4.060" diameter cylinders with high-compression 10.5:1
    forged aluminum pistons, a set of high lift Se266e cams,
    our CnC Ported Maximum Velocity Area (MVA’s) Heads
    with 2.120" diameter intake valves, perfect fit pushrods and
    gaskets. Heads are machined to accept automatic compression
    releases (sold separately). to get the air to the heads
    you need a big bore throttle body. this kit includes our
    58mm throttle body along with large fuel injectors. to top
    off the kit we’ve also included our very popular eFI Super
    tuner. requires separate purchase of Air Cleaner Kit, Cam
    Drive retention Kit P/n 25566-06, Cam Spacer Kit P/n
    25928-06, and Crankcase Boring tool Kit P/n 94419-06.
    for race application only.
    Fits ’07-later Dyna®, ’07-later Softail®, and ’07 touring
    models. Also fits ’06 Dyna models when upgraded to 4-3/8"
    Stroker Flywheel P/n 23729-07. Cannot be installed on 110ci
    CVO™ models, or any twin Cam models previously upgraded
    to a 110ci motor. requires separate purchase of modelspecific
    Automatic Compression release Wiring Harness Kit.
    not compatible with cruise control.
    27559-08D Black. $3,099.95
    27561-08D Silver. $3,099.95
    Fits ’08-later touring models. Also fits trike models. Cannot
    be installed on 110ci CVO models, or any twin Cam models
    previously upgraded to a 110ci motor. requires separate
    purchase of model-specific Automatic Compression release
    Wiring Harness Kit.
    27525-08D Black. $3,099.95
    27526-08D Silver. $3,099.95
  • wooleybull
    wooleybull
    Thanks for the replys, mine is 103 atm and they will cover the labor charges while fixing the oil leak.
    cheers Michael
    Give Rick from Sunshine coast Harley a call he had this kit on his ultra. He is a big fan of the kit.
  • Trek52
    Trek52
    i wish I could get it on my bike for $3500 !!
  • sam1085
    sam1085
     my brother has a 113 kit in a 2010 street bob. the bike was bought brand new with 113 kit installed and screaming eagle slip ons and was dynoed at greens in newcastle at 118hp at the wheel. the bikes down the track and went 11.04 2nd run ever, rode it there and home too.
    bikes also been to the island and back from sydney and has done 16000km and hasnt missed a beat.
    great fun motor that wheel spins all the way through first second and into third but is also fine to just cruise around on too.
    worth every cent for $3500!
  • PUNJABI_DuDE
    PUNJABI_DuDE
    Hey Bull so what did you end up with on your 2012 fatboy? Did you go with the 113 kit and if yes any feedback will be great.
    regards
    Shazz
