Online: SoftailNewby
Hard clutch Lever
  • Monk
    Monk
    Hiya folks,just wondering if any one has a salution to a hard clutch lever.My ride is a 85 Wideglide, 4 speed Evo.Ive just done a mini rebuild and for some reason the clutch is a pig to pull on, especialy after just fitting 16 inch apes on 6 inch risers.Cable is new and is adjusted as per manual.Clutch is a Barnett. Not that I can read in the manual ( unlessIve missed it) the clutch adjuster plate has three settings, A B C would changing position make any differance in the feel of it??  got me buggered, thanks in advance for any help folks, cheers.
  • Monk
    Monk
    thanks guys, cable is brand new and has a clear path, looks like Im going to play with settings.
  • Monk
    Monk
    Many thanks for all that Chris
  • Monk
    Monk
    All sorted now, a little oil in the new cable,cleaned clutch plates,new hub bolts, used B setting, adjusted clutch and all is good in the world.Can now pull clutch lever with 2 fingers, a very happy man I can tell ya.Thanks again to those who gave advise, cheers Monk
