Online: Retroman, beaglebasher
Forward Controls
  • Gavin2332
    Gavin2332
    Hey Guys,
    Need to ask for help here, ordering bits and pieces for my Kraft tech frame i have come unglued with forward controls. I'm very new to this and i'm unsure which ones. In the Accutronix site there it lists from 84-99 softails and customs  and also 84 and up and 2000 up softail . I understand some of them do not have the master cylinder mounted to the controls. Can any one explain Whats the differance between them all?
    Thanks
    Gav
  • Spero
    Spero
    Hey mate, I can't help you with the explaination of the different forward controls on offer but I can put you onto a good website that i'm currently buying mine from in the states. The website is http://www.twistedsteelchoppers.com/ & the guy  i've been dealing with's name is Mac, he's been very helpful explaing the different options available for my ride & they seem to be cheaper that buying them directly form Accutronix.
    Cheers, Spero..
    Kraft tech frame use evo softail controls, if your planing on engineering the bike the foot pegs must have 50 0/0 of rubber
  • Gavin2332
    Gavin2332
    Thanks Walka and Spero for the help. Made it a heap easier for me
