Can I run 98 fuel in a 2003 Fatboy
  • mwez
    mwez
     Gday, just joined this forum so I hope some one can help. I have just bought a 2003 Fatboy anniversary model. This is the 1st HD I have owned, but I am getting heaps off back fires and quite often she just dies when I take of from lights etc or pulling up unless I keep giving her heaps of revs, the dealer told me 91 Octane was fine, it was really bad, I went to 95 and that has made it much better but I have now put a tank of 98 in. My question is does anyone know if this will help and being a carby model is it ok to run 98 octane. Any suggestions or help greatly appreciated, cheers mwez
  • mwez
    mwez
    Thanks for that, I reckon a good tune might be good place to start and see what happens from there, so 98's no problem by the sound of it, thanks appreciate your help folks.
  • mwez
    mwez
    Thanks everyone for the info, fcked if I know i might just take it back and spend the bloody money and get a full service and tune, that way if they fck it up its their problem. The 98 does appear to have helped plus the last few rides I have really been giving it a fist full of throttle through the gears and it seems to be getting better so I am now wondering if it's been a while since it's had a good flogging and the carbon has built up Cheers
  • simmac18
    simmac18
    mate 98 runs good all the way 95 will run fine in your motor, but I would say you've got carby issues
    98 bp only , your carb jetting  & mixture is not set up + would be best too clean fuel tank 1st  etc then jet carb , they are very lean from the factory
